Poor Extruding on Corners
Posted: Sat Nov 05, 2016 6:55 pm
by aerouta
So I just installed the last delta arms from SeeMeCNC. I have run through the calibration several times but I am still getting poor extrusion on the edges from my print. It seems to extrude poorly right after rounding a corner.
Re: Poor Extruding on Corners
Posted: Wed Nov 09, 2016 10:44 pm
by aerouta
anyone have any thoughts on this?
Posted: Thu Nov 10, 2016 12:19 am
by IMBoring25
There's a function called Pressure Advance that adjusts the amount of filament pushed during speed changes. All my experience has been using the firmware implementation on my Duet. Repetier doesn't have a firmware implementation but I know the standalone version of Slic3r has it (designated as experimental) and other slicers might as well. It could be worth a shot to experiment with it.
Posted: Thu Nov 10, 2016 2:43 am
by nebbian
Try bumping up your acceleration and/or jerk settings in the printer firmware.
Posted: Thu Nov 10, 2016 9:58 am
by aerouta
nebbian wrote:Try bumping up your acceleration and/or jerk settings in the printer firmware.
I can give it a try, how will print head acceleration help extrusion performance around corners?
Posted: Thu Nov 10, 2016 9:24 pm
by nebbian
aerouta wrote:nebbian wrote:Try bumping up your acceleration and/or jerk settings in the printer firmware.
What's happening is that the pressure that is built up in the bowden tube while doing the line, will remain while slowing down for the corner. This will overextrude while slowing down, and then underextrude while speeding up after going around the corner. This is evident from your prints (if you know what you're looking for).
Another option is to use a flying extruder. This reduces the length of bowden tube by a large factor, so reduces this spring effect correspondingly.
I've been using this flying extruder setup for several months on both my deltas, and the print quality is far better after installing it:
http://www.thingiverse.com/thing:1259941
Posted: Sat Nov 12, 2016 10:38 am
by aerouta
nebbian wrote:aerouta wrote:nebbian wrote:Try bumping up your acceleration and/or jerk settings in the printer firmware.
That is exactly what is going on. I have not really noticed it before. Your flying extrude is quite the setup. Seems like there should be less invasive solution that takes me half way there??
Posted: Sun Nov 13, 2016 8:15 am
by nebbian
Yes:
Bump up your acceleration and/or jerk settings in the printer firmware, and also in your slicer settings.
Posted: Tue Nov 15, 2016 3:50 pm
by aerouta
This provided some improvements. My current settings are:
Acceleration - 3100
Max. Jerk 55
Is this normal?
