back to re calibration .7 noz printed test cube 20x20 looks beautiful Kiss setting included. BUT i have questions
1. what causes the lift in the corner where it starts the next layer and how do you stop that
2. why and what would cause the cube to be outa sq. 20.03 x 19.46mm
3. in Kiss where is the multiplier setting still trying to figure that out from begging thread in this post
- corner lift
KISSlicer - PRO
; Windows
; version 1.1.0.7
; Built: Mar 14 2013, 14:10:34
; Running on 4 cores
; Saved: Tue Feb 11 10:58:35 2014
; '20mm_cube (1) 7noz v3.gcode'
; *** Printer Settings ***
; printer_name = Rostock MAX
; bed_STL_filename = /Users/mhackney/Desktop/3DPrinting/RostockBuildPlatform.stl
; extension = gcode
; cost_per_hour = 0
; g_code_prefix = 4732380A4D31303420533C54454D503E0A4D31393020533C42454454454D503E0A4D31303920533C54454D503E0A4D34322050362053323535
; g_code_warm = 3B2053656C6563742065787472756465722C207761726D2C2070757267650A3B2035442D7374796C650A543C4558542B303E0A4D31303420533C54454D503E0A
; g_code_cool = 436F6F6C2047436F64650A3B2047756172616E746565642073616D652065787472756465722C20636F6F6C696E6720646F776E0A3B2035442D7374796C650A4D31303420533C54454D503E0A
; g_code_N_layers = 3B204D617962652072652D686F6D652058202620593F
; g_code_postfix = 4731205837302059302046353030300A473238
; post_process = NULL
; every_N_layers = 0
; num_extruders = 1
; firmware_type = 2
; add_comments = 1
; fan_on = M106
; fan_off = M107
; fan_pwm = 1
; add_m101_g10 = 0
; z_speed_mm_per_s = 15
; z_settle_mm = 0
; bed_size_x_mm = 280
; bed_size_y_mm = 280
; bed_size_z_mm = 300
; bed_offset_x_mm = 0
; bed_offset_y_mm = 0
; bed_offset_z_mm = 0
; bed_roughness_mm = 0
; travel_speed_mm_per_s = 500
; first_layer_speed_mm_per_s = 10
; xy_accel_mm_per_s_per_s = 1500
; lo_speed_perim_mm_per_s = 10
; lo_speed_solid_mm_per_s = 10
; lo_speed_sparse_mm_per_s = 10
; hi_speed_perim_mm_per_s = 30
; hi_speed_solid_mm_per_s = 30
; hi_speed_sparse_mm_per_s = 30
; ext_gain_1 = 1
; ext_material_1 = 1
; ext_axis_1 = 0
; ext_gain_2 = 1
; ext_material_2 = 0
; ext_axis_2 = 0
; ext_gain_3 = 1
; ext_material_3 = 0
; ext_axis_3 = 0
; model_ext = 0
; support_ext = 0
; support_body_ext = 0
; raft_ext = 0
; solid_loop_overlap_fraction = 1
; *** Material Settings for Extruder 1 ***
; material_name = ABS-Black
; g_code_matl = 3B204D617962652073657420736F6D65206D6174657269616C2D737065636966696320472D636F64653F
; fan_Z_mm = 0
; fan_loops_percent = 0
; fan_inside_percent = 0
; fan_cool_percent = 0
; temperature_C = 220
; keep_warm_C = 175
; first_layer_C = 220
; bed_C = 100
; sec_per_C_per_C = 0.00681818
; flow_min_mm3_per_s = 0.5
; flow_max_mm3_per_s = 10
; destring_suck = 1
; destring_prime = 1
; destring_min_mm = 1.5
; destring_trigger_mm = 10
; destring_speed_mm_per_s = 20
; Z_lift_mm = 0
; min_layer_time_s = 10
; wipe_mm = 2
; cost_per_cm3 = 0
; flowrate_tweak = 1
; fiber_dia_mm = 1.72
; color = 0
; *** Style Settings ***
; style_name = .7 Nozzle - Infill 50% - .35mm Layers
; layer_thickness_mm = 0.45
; extrusion_width_mm = 0.7
; num_loops = 1
; skin_thickness_mm = 0.7
; infill_extrusion_width = 0.77
; infill_density_denominator = 11
; stacked_layers = 1
; use_destring = 1
; use_wipe = 1
; loops_insideout = 0
; infill_st_oct_rnd = 0
; inset_surface_xy_mm = 0
; *** Support Settings ***
; support_name = sample support
; support_sheathe = 0
; support_density = 0
; support_inflate_mm = 1
; support_gap_mm = 0.5
; support_angle_deg = 0
; support_z_max_mm = -1
; sheathe_z_max_mm = -1
; raft_mode = 1
; prime_pillar_mode = 0
; raft_inflate_mm = 1
; *** Actual Slicing Settings As Used ***
; extrusion_width = 0.7
; num_ISOs = 1
; wall_thickness = 0.7
; infill_style = -1
; support_style = 0
; support_angle = -0.1
; stacked_infill_layers = 1
; raft_style = 1
; extra_raft_depth = 0
; oversample_res_mm = 0.125
; crowning_threshold_mm = 1
; inflate_raft_mm = 1
; inflate_support_mm = 0
; model_support_gap_mm = 0.5
; support_Z_max_mm = 1e+020
; sheathe_Z_max_mm = 0
; Speed vs Quality = 0.50
; *** G-code Prefix ***
thks
