Upgraded Heated Bed Issues
Posted: Sat Jul 18, 2015 9:59 am
Hello,
I just finished upgrading my Rostock max heated bed and I am having an issue.
I bought a 120VAC 550W mat with builtin thermistor along with a MIC-6 plate from sandsmachine. From there, I attached the mat to the aluminum and mounted it to the printer. I also bought an SSR and did all the electrical work to get it running. However, here's the issue at hand. The thermistor inside the heated mat heats up to 90 degrees in about 20 seconds, but the aluminum doesn't get to 90degrees until about 9minutes later.
Since the purpose of the thermistor is to give the temperature of the top of the plate, what are my options as to fix this? I've heard of people doing similar things but I have not found any information regarding this.
Thanks,
Addison
Thanks,
Addison
