Interesting power supply
Check out how others are building and modding their own heated beds
doctorgonzo
Post by doctorgonzo »
http://www.lipoconnectionsolutions.com/ ... s-2447.htm
Anybody looked at these?
47A should be enough, eh?
Chris
Re: Interesting power supply
For all of your 24v welding needs...
KAS
Post by KAS »
Ive seen a couple of videos of people converting them for bench-top power supplies, but the size might be a tad large to conceal in the base of the Rostock.
doctorgonzo
Jimustanguitar wrote:For all of your 24v welding needs...
I need to weld my ABS parts to the build plate, with less than an hour of warm-up time.
I ordered one of these just now, we'll see how it goes.
KAS
Post by KAS »
Did you look at ebay at all?
These are all over the place.
http://www.ebay.com/itm/LOT-OF-2-HP-406 ... 27f1413dd6
Eric
Post by Eric »
I wrote about server supplies in this forum years ago...it remains true today: http://forum.seemecnc.com/viewtopic.php?f=12&t=889
Two identical 12V supplies can be used in series to create a 24V supply. The only catch is the second supply has to be opened and have the DC ground isolated from the case to avoid a short circuit through the cases. Fairly easy for someone who knows what to do....but can be challenging for someone who doesn't.
Still, assuming shipping is reasonable, that's a fair price for an already converted pair of supplies. He's created a $60 product by adding $5 of parts and a little labor to recycled supplies with a resale value of about $10 each. Not everyone is handy enough to do it themselves.
You'll have to plug them both into a power strip and use that to turn them on/off. There are no switches on the units.
Return to “Heated Bed How-To's”
