Rev3 Onyx on 48V?
Posted: Tue Mar 17, 2015 1:29 pm
by doctorgonzo
I have a 48V 7.3A power supply kicking around. Any reason I can't run my Onyx on this with a SSR?
Chris
(not an electrical guy)
Re: Rev3 Onyx on 48V?
Posted: Tue Mar 17, 2015 1:55 pm
by Tincho85
48v omg... don't know really, but I think you need more amps.
Posted: Tue Mar 17, 2015 2:11 pm
by Tonkabot
It will draw way more current than you have available. burn out your 48v supply or blow fuses/breakers...
Posted: Tue Mar 17, 2015 2:15 pm
by doctorgonzo
V=IR is a bummer.
Posted: Tue Mar 17, 2015 2:16 pm
by mvansomeren
I'm thinking that it will take down the electrical grid in Atlanta
Seriously, though, even with a voltage regulator to get it to the proper voltage, you'll need more available current than the power supply has. The results will probably result in the smoke escaping. And once it's out, you'll never be able to get it back in.
Posted: Tue Mar 17, 2015 2:39 pm
Yeah, unless that supply is an expensive current limiting one, an Onyx at 1 ohm will overdraw that supply by a factor of 7 or 8.
Back to the drawing board.
Posted: Tue Mar 17, 2015 3:05 pm
by doctorgonzo
http://www.amazon.com/Genssi-14-6A-Regu ... B005CLDOW8" onclick="window.open(this.href);return false;
I have one of these too, is it gonna be enough?
Posted: Tue Mar 17, 2015 3:22 pm
by 0110-m-p
You really need a 20A+ 24V power supply to run a R3 Onyx directly.
Most R3 beds are a little above 1-ohm (why they are being sold for cheaper since they have too high of a resistance to generate the power/heat required on 12V). So if resistance=1.2ohm and you have a 24V power supply, V=IR says that you need a power supply that can supply 20A.
EDIT: Also a good tip...when you double the voltage of a heater you quadruple the power requirements.
Posted: Tue Mar 17, 2015 3:42 pm
by KAS
Don't feel bad, I have a 1300w 65v Toroidal power supply I cant use either.
It's looking like SP-750-24 is the magic power supply to find.
Posted: Tue Mar 17, 2015 3:52 pm
by doctorgonzo
KAS wrote:Don't feel bad, I have a 1300w 65v Toroidal power supply I cant use either.
The Meanwell SP-750-24 is $200
Posted: Tue Mar 17, 2015 10:48 pm
by JFettig
Or $50 on eBay
