How did I find the lizard/dragon? Or?Tinyhead wrote:Wow! You deliver quickly!
How do you find it? The lizard looks really good. Do you find you get much smearing of colors? I see the cube, but not sure if it's intentional looking at the lizard print and how clean it came out.
http://www.thingiverse.com/thing:17309/#files" onclick="window.open(this.href);return false;
The cube is the purge tower. Because both colors mix inside the heat block, every color switch it purges into this sacrificial tower. You can see it in the video.
The key to clean color transisitons is in the retraction. My retractions are 4mm @ 100 mm/s. I don't see any colors where they shouldn't be, it looks better than the E3D demo prints if I do say so myself.
Thanks! Next I will do a larger print, the first one was small/fast to see how things went.BenTheRighteous wrote:Looks freaking awesome!
