connection on Rambo v1.3 for 40mm Rambo Cooling Fan?
hrodman
Post by hrodman »
Hi,
Total Noob Here.
I'm building a Rostock V3 and can't find the for sure right connection for the 40mm Rambo cooling fan on the board -- is it Fan 2? My board doesn't have the connection in the lower right shown in most documentation... Thanks for any input.
Best,
Halsey
joe
Re: connection on Rambo v1.3 for 40mm Rambo Cooling Fan?
Post by joe »
Any constant (always on) 12v source will work.
hrodman
Post by hrodman »
Thanks Joe -- here's a picture:
Would this be a constant source? As far as I can tell, the answer is Yes -- but hoping to confirm...
Thx!
Post by Mac The Knife »
Page 183 of the V2 assembly manual shows that the cooling fan leads get soldered to the board at the bottom right hand near the E1 motor connector.
http://download.seemecnc.com/rostockmax ... -Guide.pdf
hrodman
Post by hrodman »
Thank you -- turns out the connector was left off the board -- I will solder per your suggestion
According to the manual,,, there is no connector there,,, they expect you to solder directly to the board.
barry99705
Post by barry99705 »
Page 183 of the manual....
KAS
Post by KAS »
I bet the OP is going nuts right now with the replies :) He's building a V3, and the instructions do state; 40mm fan connects to 12v AUX output
Guide, step 15: http://seemecnc.dozuki.com/Guide/Step+3 ... ssembly/44
RAMBo connection image: https://d17kynu4zpq5hy.cloudfront.net/i ... ZuRqS.huge
barry99705
Heh, well, sombitch! Must be an updated rambo.
Return to “The Build Zone”
