IR level sensor or FSR's
Building a metal max, using a Duet controller. Do I go FSR's or the IR proximity sensor. I use a glass surface and sometimes I use buildtek
Re: IR level sensor or FSR's
If you use multiple bed surface's, I'd use FSR's. Different surfaces and coatings will trigger the IR sensor at different heights, requiring tweaking.
You can also do Z probing. http://www.thingiverse.com/thing:1069281" onclick="window.open(this.href);return false;
Another option is an accelerometer mounted to the hotend that can act like a z probe. Hopefully the Eris will be a wild success and there will be kits available to us soon!
A friend build a Pup delta, and it actually mounts the hotend slightly loose and has a snap switch that's triggered that way...
That being said, I'm doing a build right now and I went with FSRs. Betweeen OpenDact and MHackney and 626Pilot's work, I felt like it gave me the best options.
