So I've been putting together a Rostock Max V2, and I noticed something very strange.
The guide shows an ATX power supply, with multiple wires coming out of it. However, I received a very different power supply.
Here are some pictures:
(Sorry about the bluriness)
[img]http://i.imgur.com/dcEB8uc.jpg[/img]
[img]http://i.imgur.com/mGtbPE0.jpg[/img]
It has no brand on it, and no wires whatsoever, only a set of ports for power.
Am I missing something obvious, or is this not the right power supply? Thanks for any help.
[Solved] Odd Power Supply
- Noob
Re: [Help] Odd Power Supply
You might be working off an older manual.
Try this one: http://download.seemecnc.com/rostockmax ... dition.pdf" onclick="window.open(this.href);return false;
There's no "might" about it.
BTW, cool use of the "earthquake" image filter.
- Noob
There's a foruth edition!?!? Wow, was only on the second lol. Thanks!KAS wrote:You might be working off an older manual.
Re: [Solved] Odd Power Supply
Lay off the coffee man.
The power supply was changed at some point you have the newer version.
