I would appreciate some input on this. What should I not do? What should I do that I dont have listed?
Here are the plans:
- Install some lighting mounted in the cabinet. I have some 12v potted LEDs. I figure I can run these off the printer itself with a plugin style disconnect if I need to move printer around. These lights will be hard mounted and stay in cabinet.
- Arduino running a temp sensor tied to exhaust fan in top to maintain a set temp. A smoke/fire sensor on Arduino in top of cabinet. The Arduino will also control an optically isolated relay that can cut power to the entire cab based on smoke/fire sensor or other inputs.
- RPi Repetier server. Already running this.
- RPi Repetier Cam host. Have camera. Just need to set this up. Not sure if I can tie the two together into main Repetier server interface. I think you can.
- Block the upper vents. Air drawn in by exhaust fan will come from lower vents. Lower vents are below level of printer shelf.
