Check out my $20 enclosure
Holy1
Post by Holy1 »
Hi Everyone. Check out my $20 enclosure. Took 45 minutes and the warping seems to be gone. :D
Head Shot
Head Shot
Orion to Cartesian viewtopic.php?f=59&t=7808
dpmacri
Re: Check out my $20 enclosure
Post by dpmacri »
Nice! From what is the enclosure made?
Christian79
Post by Christian79 »
You cannot post something so seemingly perfect without a link to the product......
Where did you get it?
Eric
Post by Eric »
It looks like a couple generic plastic storage bins with one end trimmed off and mated top to top. I see a couple knobs added with rubber bands on this side...the other side is either the same or has some kind of hinge. Tape would work. I applaud the ingenuity and reuse of common products.
Holy1
Post by Holy1 »
Yes, 2 storage bins on their side and 3 hinges. Really works well and doesn't look too bad!
gestalt73
Post by gestalt73 »
That ingenious! Way nicer than my Hefty(tm) bag heated enclosure.
(runs off to lowe's to see if he can find bins big enough for the Max)
lordbinky
Post by lordbinky »
*looks at closet*....*looks back to printer*....It seems so wrong to cut up something so useful :cry: ... I don't know if I can do it. *Stairs at the piles of bins in the closet* :shock: That one has a scratch on the lid, guess I better replace it. ;)
bvandiepenbos
Post by bvandiepenbos »
Genius!
heads to Menards.....
TFMike
Post by TFMike »
Ok, so I'm gonna need to know where your filament roll disappeared to..?
I like the concept but I also liked the idea of using the clear 55 gallon drum liner that a user posted.
Holy1
Post by Holy1 »
The filament roll is on the desk behind enclosure on a stand. A small hole is drilled to allow the filament to enter at a descent angle.
TFMike
Post by TFMike »
Any chance you could give the details as to how you did this? Like what hinges were used, which brand and model of containers were used, what you used to cut them, etc....?
Fester
Post by Fester »
TFMike wrote:Any chance you could give the details as to how you did this? Like what hinges were used, which brand and model of containers were used, what you used to cut them, etc....?
YET what he said ....lol
Holy1 wrote:The filament roll is on the desk behind enclosure on a stand. A small hole is drilled to allow the filament to enter at a descent angle.
Can you give us a hint of where you got the containers, the brand and the size?
Holy1
Post by Holy1 »
I got them at Home Depot. Here is a photo of the label. I cut them with a good set of sheet metal shears. btw the .030 PEI material I used on the heated bed cuts well with red or green sheet metal snips. The hinges were also from Homo Depot.
Thanks for the pictures and the sourcing of the materials, the containers look like Canadian, I hope the states have something similar.
