Rostock Max v2 continuously restarting
Posted: Thu Feb 25, 2016 5:14 pm
So, I got my machine assembled without too many hitches, it had been making decent prints and I was chipping away at calibrations while I built the table it is to live on. I got the table built, moved the machine across the room to the table, and now when I turn it on it continuously cycles between the "Repetier 091S Rostick MAX SeeMeCNC" startup splash screen thing and the normal "Noz: Bed: Rostock MAX OK, etc." screen. I assume it is restarting every time it does this.
I cleared EEPROM, and re-uploaded Repetier (downloaded via the link in the instructions). Didn't do anything.
I checked the forums as best I could and found some similar issues that came up when they started up the hot end or heated bed, and it was suggested there that the restarting is symptomatic of a short somewhere, so I went looking for shorts. I haven't found any wires rubbing against pulleys, or other obvious wiring problems, except that one of the wires in the screw terminals on the connector that plugs into the RAMBo was loose. Not disconnected, but loose. So, I fixed that with no change.
I'll go through it some more hunting for shorts, but assuming there aren't bare wires touching each other somewhere, what's my next step? Then it's either the power supply or the RAMBo itself, right? How do I isolate the problem further before I go buying new parts?
Or, better yet, what's the simple solution to this common problem?
To sum up: Machine was working great, got moved and was continuously restarting. There are no obvious shorts.
