Way too long print times for something I thought was simple
Posted: Thu Feb 18, 2016 2:59 pm
I'm trying to print a cube-ish thing that I designed. When I load it into matter control it has a print time of about 40 hours. The size of the shape is about between a baseball and a softball size.
I did substract material from the inside to make a hollow shell but I can't figure out what I need to do to make matter control see it as a single walled shell instead of something that is has to infill.
(In a horrible attempt at ascii art: I keep getting |||---||| and I want |||||| (the --- are infill options)).
I think that is the main problem that is making it think it will take so long.
Attached is an image of that I'm trying to print. Do I need to submit the STL as well? There is an opening on one of the triagles which will be used to access the cavity. I'll be printing another part that will snap in (or glued in) once the stuff is added inside the cavity. That last picture I had forgotten to add the decorations to that one side you see blank....
