Dead Rostock Max V2
Posted: Thu Feb 04, 2016 4:20 am
I printed 3 parts with my newly build 3D printer.
Then I installed the PEEK fan. I recalibrated everything (and did the PID routine)
During my first print with this new setup, suddenly the printer stopped (the power supply fan kept on turning.)
The LCD panel is also dark.
I opened the printer and tested the fuses on the Rambo for continuity. The F3 5A fuse is blown.
What I think i should do now is:
buy a new 5A fuse (and some spares) -> but the shipping cost is rather high from the US based shop to Belgium -> any suggestions for a european source for this? (a modification for a car fuse seems to farfetched for me)
how should i best diagnose the underlying problem? Disconnecting al the connectors of the parts supplied by Fuse 3 and check them for continuity? -> visually inspect different parts/wires?
Could a contact between the layer fan wires have caused the problem? They where in contact, but i'm printing in ABS and the layer fan control was 0%. So I think this is not a problem.
