leveling screw fix?
Posted: Tue Mar 17, 2015 10:42 pm
by Behold
I have a ver 1 max. I am tring to address the leveling screw construction on my machine. It seems that the screws do not screw perfectly straight up and down. Has anyone address this issue? Is there a mod?
what I would like to do is place a longer screw in place of the ones there and make some sort of printed part that gives more "meat" for the screw to stay true. Is this idea silly or has someone already solved it?
Re: leveling screw fix?
Posted: Tue Mar 17, 2015 10:59 pm
by Nylocke
I'm assuming the carriage design didn't change too much since the V1s (honestly I can't remember what the V1 I built looked like, been a year or so since Ive seen it). If thats true then the screw has to thread through a hole in the side of a slant, so the threads don't engage on the whole circumference of the hole right away, so the screws don't quite seem to want to thread straight all that often. I'm not aware of any carriage redesigns that anyone has made other than the magnetic ones and the one Jfettig made for the Trick Laser arms. I am aware, however, that SeeMe redesigned the Cheapskates to move the carriage arm mounts up so long screws aren't necessary. The TrickTrucks also accomplish this, but all the hardware needed for them makes it a $100 upgrade.
What I would do is ask if anyone has some cheapskates (newer design) that they aren't using anymore since the TrickTruck upgrade, or I would ditch the whole "adjust this endstop screw" method and move to the EEPROM method of adjusting the tower offsets. Or you could design that thing you're wanting.
Posted: Tue Mar 17, 2015 11:04 pm
One option would to buy some knurled thumb screws that look like these:
https://www.unicorpinc.com/images/WEB%2 ... l-%20B.jpg" onclick="window.open(this.href);return false;
The head is much wider than a normal screw and can sometimes help to take care of a misalignment of the screw and endstop.
I do hope this is some help to you.
Posted: Tue Mar 17, 2015 11:11 pm
You could also drill into the melamine and thread a screw directly into it for adjustment.
I believe that you need to flip the switch over to land everything just right.
[img]
http://i.imgur.com/qIdo2xs.png[/img]
This is assuming that you can drill straighter than they can, though.
Posted: Tue Mar 17, 2015 11:43 pm
by teoman
Attach any protrusion adjustable or fixed and use eeprom to adjust.
Posted: Wed Mar 18, 2015 8:01 am
teoman wrote:Attach any protrusion adjustable or fixed and use eeprom to adjust.
Yeah, if you flip around the snapswitch, the lever hits the carriage, so no screw needed if you're leveling it in EEPROM.
Posted: Wed Mar 18, 2015 1:06 pm
by Behold
i am conflicted with using eeprom. I've read that (especially when levelling) you do not want to use eeprom.
Posted: Wed Mar 18, 2015 1:25 pm
by Nylocke
That's a relic of the past. Changes used to be made via modifying the config.h file and reuploading the firmware. EEPROM would affect this, as the EEPROM overrides these values. Now most all calibration variables are stored in EEPROM.
Posted: Wed Mar 18, 2015 2:06 pm
by Behold
thank you
Posted: Wed Mar 18, 2015 2:09 pm
by teoman
Search the forum. I have posted a link several times. I shall try to find it and post it again.
Posted: Wed Mar 18, 2015 2:33 pm
by Behold
I appreciate it but I can do a search for your comments and find it too... Thanks
Posted: Wed Mar 18, 2015 2:44 pm
by teoman
Posted: Wed Mar 18, 2015 2:59 pm
by Behold
I didnt perceive it that way.
I know its rare but i believe in the old school way of communicating.. when I say thanks i actually do mean it and am not being sarcastic or snipey
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Posted: Wed Mar 18, 2015 5:28 pm
by teoman
Perceive it which way?
It is a bit tricky to find. I search for "AFM probe" and find it.
Posted: Wed Mar 18, 2015 5:44 pm
by Behold
sorry I read the signature and thought it was a comment. apologies
Posted: Wed Mar 18, 2015 6:10 pm
by teoman
And coincidentally, i am on a mobile phone
![Smile :)](./images/smilies/icon_e_smile.gif)
