Layers Splitting Apart
Posted: Sat Jul 06, 2013 6:41 pm
Hello again. So I seem to have a very nice printer over here, making some amazing looking vases. I've moved onto making complete structures now, but I am running into a serious splitting problem. It seems that some of the layers have trouble adhering to each other, so they split apart, making big gaps in the print. This is the thing I am trying to print: http://www.thingiverse.com/thing:110717
Bellow are some shots of the model after it is printed, showing off the splits.
https://www.dropbox.com/s/nm46ycoidy5mm ... .28.07.jpg
https://www.dropbox.com/s/fkbcu3syh0uq4 ... .28.17.jpg
https://www.dropbox.com/s/t7yq6tgfcz3hr ... .28.28.jpg
https://www.dropbox.com/s/uk1ocpshh3pb1 ... .30.51.jpg
As you can see in the pics, there are a lot of splits in the object. Bellow is the printing information:
I still need to calibrate the hot end temp. I am using one of the new J-Heads from hotends.com. Any ideas what could be causing these big splits? Temp not high enough (I think the hot end is fine, it gets quite a few bubbles, but not to much to affect the print quality), object cooling at different rates, ect? Thanks!
; layer_height = 0.3
; perimeters = 4
; top_solid_layers = 2
; bottom_solid_layers = 3
; fill_density = .20
; perimeter_speed = 40
; infill_speed = 60
; travel_speed = 200
; nozzle_diameter = 0.5
; filament_diameter = 1.67
; extrusion_multiplier = 1
; perimeters extrusion width = 0.70mm
; infill extrusion width = 0.70mm
; solid infill extrusion width = 0.70mm
; top infill extrusion width = 0.70mm
; support material extrusion width = 0.70mm
; first layer extrusion width = 0.70mm
Hot End: 225C
Bed: 100C
