Extruder Temperature Fault
Posted: Mon Apr 01, 2024 12:55 pm
I have a RostockMax V3.2 with Duet board and SE300 dual feed hotend. It was purchased 3/24/18.
I have a random issue where the hotend heater will have a fault for temperature out of range. I haven't been able to tell if the temperature abruptly peaks too high to create the fault or if it drops down which causes the fault. The graph just shows a steady decline.
I have replaced the entire SE300 hot end assembly without a change. Both assemblies (board, heater, sensor, dual filament feed, etc. everything except the whip cable) have the same issue on occasion.
I have replaced the config file with several different files that Steve sent over the years, and that doesn't solve the problem.
I tuned the heater loop using the procedure that Steve supplied. That sometimes appeared to help for a while, but did not resolve the problem.
I have secured the whip so that it cannot flex the connectors on the hotend, and that doesn't seem to make a difference.
The firmware is still the same as Steve installed last spring, which worked fine for several months before the problem started to occur.
I thought it might have been a Cura setting, but it doesn't always fail at the same point in a print file.
So I'm down to several possibilities that I can think of:
The Duet card is occasionally failing. I had one print that I sliced for an Orion and accidentally sent it to the Rostock. It failed from the start and the resliced file ran correctly, but it may have caused a problem with the Duet, or the Duet may have developed a problem due to age.
The whip may have an internal problem or a poor connector. It is one that I did rewire when I upgraded to the SE300 from the original SE280.
Do either of these seem likely? Are there any other possibilities that you can think of for me to check?
