My 3D printer was printing fine. I thought it would be a good idea to update the firmware to V3.4.4 I have not been able to get a clean print since.
I have run the Delta Calibration several times. I have included a picture to show where it seems to "not print" on the bottom right portion. This is the same file that was printing correctly before I upgraded the firmware. Any suggestions would be appreciated. NOTE--I stopped the print after I thought there was enough there to show what was happening.
Rostock Max V4 Bed Mapping Issue?
- IMG-1793.jpg (3.15 MiB) Viewed 1182 times
Re: Rostock Max V4 Bed Mapping Issue?
I've got a similar issue with my v4. Are you seeing that after a normal delta cal, or after you've done a height map? How does it print without the height map?
I've pinged Part Daddy on this, so hopefully he'll stick his nose in soon.
