rostock max v2 comunication problems
gurusonwheels
Post by gurusonwheels »
my rostock max v2 all of a sudden developed a issue of spitting out weird chars in the gcode log .
i have tried to reflash with usb cable hooked directly to rambo controller but it fails to connect with sync problems .
i even tried reflashing bootloader using a ardunio as isp programmer connected to icsp headder .
flashes fine with no errors .
but still can not flash firmware with cable connected to usb port of board .
tried flashing compiled rostock.hex file using programmer on icsp header
flashes fine .
system boots up display and menus all work including homeing and heating .
however when i connect something like simplify3d and watch the verbose log for a few secs this is what happens .
Attempting connection at \\.\COM3...
READ: start
  Connected to machine!
SENT: T0
READ: Info:External Reset
READ: Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
READ: Free RAM:794
READ: Autoretract:0
READ: X:0.00 Y:0.00 Z:0.000 E:0.0000
READ: SpeedMultiply:100
READ: iis2dh accelerometer initializing...
READ: ok
SENT: M105
READ: ok
READ: T:20.86 /0 B:20.86 /0 B@:0 @:0
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: wait
READ: ok
READ: wait
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: wait
READ: ok
READ: wait
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: wait
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
SENT: M105
READ: ok
READ: wait
READ: wait
SENT: M105
READ: ok
READ: T:20.<6 /0 b:20.86</0 B@:0 @:0
READ: w}iw
SENT: M105
READ: okí
SENT: M105
READ: W;2°.<6?/0°z:²?.<¶¿/<¾C`º<<~;?Ëw}iwËok
READ: W;²8.¾6</8<r;2>/?6?/<>{|º? p:<
wymv
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
Disconnected.
  Testing plaintext communication protocol...
  Testing binary communication protocol...
  Testing alternate communication protocols...
WARNING: Device unplugged while connected to port
Disconnected.
  Connection failed.
after that communications are dead again unless i re-flash with icsp header using programmer .
then it all repeats .
have not tried printing from sd card yet . but im assuming it will work as it seems it a communication issue
of some type .
any ideas? is it a dead board ?
i have the updated 280 head on it as well as the better arms .
Wilsonngu
Re: rostock max v2 comunication problems
Post by Wilsonngu »
Try Mattercontrol, other slicing softwares if that does the same thing you can conclude it's the communication from Rambo-PC for sure. If you have a spare USB to Rambo cable I suggest replacing it otherwise that might be the issue.
