Epilog laser won’t go home, looking for miracle solution
Posted: Sun Jun 23, 2019 11:05 am
Hiya laser community
We have a 50W Epilog Zing CO2 laser. The Y-Axis keeps homing at about the 6.5" mark out on the ruler guide AS IF the rotary attachment were connected, even though its not.
When working properly, the Zing recognizes the rotary is attached and automatically adjusts the home position for it. And when the rotary is disconnected, it will revert to the correct, left, rear home position for the 12x24 bed (always connect/disconnect rotary controller cable with machine off)
Up until this homing problem began, it worked flawlessly.
Here is what I've tried so far ...
As far as I can tell, the machine is working properly in all regards to hardware, but is confused about where home is, which seems like a software glitch to me.
A new control board from Epilog cost over $1K+ so I just wanted to see if anyone knew of a fix, or trick even.
Any suggestions are welcome, thanks!
- I made sure the sensor is clean and belts are tight.
- I tried turning off X/Y and moving the rail back to the normal home position
- I manually set the home to factory default positions (X -152, Y +200) using the Config Menu in the machine's LCD display
Note: There is no Restore to factory default option in the LCD Config Menu on the machine or in the Epilog driver interface on a computer.
- I tried reconnecting and disconnecting the rotary to see if that would reset it.
- Epilog Support suggested the motor wasn't pulling properly. Even though the rail and carriage seem to have no issues moving, I replaced the motor anyway.
