Hello,
I assembled the Rostock max 3.2, I had some problems to connect to duet3D here is the topic
https://forum.duet3d.com/topic/5339/pro ... -duet3d/20
now, after I change the sd card files and try to do first probe or firmware update I didn't get any response. (the firmware updated to 1.21)
update:
https://ibb.co/cuEV0o
https://ibb.co/kdWSfo
first probe:
https://ibb.co/f9TvY8
thanks,
Adi.
first probe problem v3.2
Re: first probe problem v3.2
I read through your troubleshooting steps on the Duet site, and I noticed that your SD card is addressed to "0", and that you got it to work. But the macros that you are trying to use access SD card "1".
You don't have a SD card "1", so edit your macros to point to SD card 0.
If this doesn't fix things, please post your macros here.
