V2 Firmware Questions
Posted: Fri Dec 08, 2017 12:07 am
Hey guys,
I bought a Rostock Max V2 secondhand from someone. It came installed with an E3Dv6, but the firmware was never updated to get temps above 240c. I now need to update the firmware to get the proper temperatures for different materials. I found the repetier firmware on the seemecnc github. I edited the setting "#define EXT0_TEMPSENSOR_TYPE" to 8. I am wondering if there is anything else i need to edit in the firmware. There is a section where you are supposed to select your hotend, but I am not using one of seemecnc's hotends so I'm wondering if that is going to conflict or make a difference.
Another problem... When i try and upload the firmware, i get this error message: avrdude: ser_open(): can't open device "\\.\COM5": Access is denied.
avrdude: ser_drain(): read error: The handle is invalid.
I have googled this error and none of the solutions i have found have worked for me. I tried going into the com port settings and making sure the baudrate was the same as the printers. I tried reinstalling the rambo drivers. Don't know what to try next.
The printer has been working beautifully with PLA so far.
-Bobsled
-Bobsled
