Rostock Max w/ He280 Simplify3D settings
Could anybody with a Rostock Max with the a He280 head using Simplify3D share their settings? PETG/ABS/PLA, any of them. Trying to really dial my machine in but having trouble with all the variables in the software. Is there a source online that has profiles for the various printing software titles out there? Found some Cura ones but no dice on Simplify3D. Thanks!
Re: Rostock Max w/ He280 Simplify3D settings
Anybody??? Is there nobody running a He280 with Simplify3D? Anyone know of a source that might?
I use these settings:
2mm retract
22.5mm/sec retract speed
4mm z-lift on retract
250mm/sec rapid moves
You want to also make sure that you're not printing too hot, especially with PLA. That leads to stringing. Note that the optimal printing temp with PLA can change with /every/ spool, especially some of the cheaper Chinese imports.
2mm retract
I have recently also purchased Simplify3D recently, I'm running into the issue where it won't center the part if you use all the bed.
i.e. I can print a part 280mm diameter but if I bring in a part that size the bed has to be set to be about 350mm diameter before it'll center the part on it.
At the moment I'm not sure if this center is really the center of the printer, anyone else seen this and can short cut me to the solution?
I'm not in-front of the software, but you should have an Orgin settings option in the FFF (might be under gcode) . Make sure that's 0,0,0.
Wait. not 0,0,0. It should be half of your bed diameter. so if you set the diameter to 300; it should be 150,150,0
- Plasticator
A little late to the game on this thread, but here is my factory file for my V3.
https://dropfile.to/Sfm5kSw/
This happens all the time to me in S3D. All I do is to go to the top view and manually center the image. It's not elegant but it is easy and it works.Doug68 wrote:I have recently also purchased Simplify3D recently, I'm running into the issue where it won't center the part if you use all the bed.
