Hi guys so last night I smelled somthing odd and wisely decided to stop the print and power off my Rostock Max v3.
After the inicial investigation I found this:
[img]https://s19.postimg.org/6wk2uuky7/Power_supply_issue.jpg[/img]
Possible cause? How to fix? How to avoid this happening again?
When I built the machine I used some pliers to crimp the ferrules, now I have this new tool:
[img]https://s19.postimg.org/qfoo47jpr/Stanley_electricians_multi_use_tool.jpg[/img]
Should I just cut the wire, get a new ferrule and go? Should I try to re crimp the other ferrules with my new tool?
Power supply - Heat bed cable melted
FranciscoJS12 | Rostock Max v3
Re: Power supply - Heat bed cable melted
I'd replace all the connectors and use your new crimping tool.
- DeltaCon
If you have enough cable length left, yes, always cut off and start a new.
Hard to see, but you could perhaps use a smaller size. If the cable has too much room left, it is prone to failure.
Thanks guys. I just cut off the burnt connector and switched to a new one, now properly crimped. All is good for now.
