Octopi placing objects outside of print bed
dsl158
Post by dsl158 »
All of a sudden octopi is placing objects on the out side of the bed [img]http://puu.sh/sTfNN/cdc6c5de3f.png[/img]
rurwin
Re: Octopi placing objects outside of print bed
Post by rurwin »
Does it still print OK?
The latest update to OctoPrint now warns when the object is outside the print area. You can disable that in Settings->Features.
It gets that size from the Printer Profile, which I just checked and it is set to rectangular. There's also a setting for the position of the origin.
But...
"This information is used for the temperature tab, the bounding box check, the GCODE Viewer and/or when slicing from OctoPrint. It does NOT influence already sliced files that you upload to OctoPrint!"
It seems to me that your slicer assumed the origin was bottom-left.
bubbasnow
Post by bubbasnow »
yea octorpint just pumps the gcode to the machine. so long as the slicer is configured correctly you should be golden.
dsl158
Post by dsl158 »
bubbasnow wrote:yea octorpint just pumps the gcode to the machine. so long as the slicer is configured correctly you should be golden.
Is there anyway to like move it to the middle in octoprint?
dsl158
Post by dsl158 »
rurwin wrote:Does it still print OK?
But...
It doesn't print well it's outside of the actual bed of the printer
IMBoring25
Post by IMBoring25 »
Where are you doing your slicing? That looks like the Slic3r-in-MatterControl error.
dsl158
Post by dsl158 »
IMBoring25 wrote:Where are you doing your slicing? That looks like the Slic3r-in-MatterControl error.
Yeah I'm slicing in matter control
IMBoring25
With the Slic3r slicing engine? That's your problem. Either use one of the other slicers bundled in MatterControl or download the standalone version of Slic3r (which will also give you a lot more options in Expert Mode). MatterControl's Slic3r integration has a bug and they don't seem interested in fixing it.
dsl158
Post by dsl158 »
IMBoring25 wrote:With the Slic3r slicing engine? That's your problem. Either use one of the other slicers bundled in MatterControl or download the standalone version of Slic3r (which will also give you a lot more options in Expert Mode). MatterControl's Slic3r integration has a bug and they don't seem interested in fixing it.
Any recommendations on which I should use? I only use matter control because everything is already kinda ok settings wise.
Post by Xenocrates »
just go to the settings and change the slicing engine to matterslice or cura
