Rostock Max v2. Been having on-and-off airprinting issues due to PLA filament melting in the cold end(EZstruder), lumping and jamming up the EZstruder, heat and pressure squishing the filament too thin for the hobbed gear to grip on, kinking/curling the filament and the incoming filament becoming instant ramen in the ezstruder, etc etc.
It's quite obvious that the cold end is getting way too hot on longer prints(>2hour), actually burns when you touch the stepper motor. It even managed to glass transition and warp the EZstruder cover I printed in PLA.
In the assembly guide v3 it says set to
Which I did, but the E value is clearly still far, far too hot.If your kit was shipped with the Kysan or Automation Technology stepper motors (we covered
that earlier, remember?), you're going to need to make a small tweak to the firmware in order to adjust
the current drive that they need.
Click on the tab in the Arduino IDE marked “Configuration.h”. At line #701, you should see
this text: #define MOTOR_CURRENT {175,175,175,200,0}.
Change that line to this: #define MOTOR_CURRENT {155,155,155,165,0}
Contrastingly, the commented portion in repetitier.ino:
Then there's this:// Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A) use 140 for xyz and 160 for the E if using Kysan motors and 175 xyz and 200 if using wantai motors
The 155 value for the XYZ haven't given me any problems, so should E be 140, 160, or 165? This issue has been an endless source of frustration with its unpredicatability and evasiveness. The printer lives in a room which reaches 35degrees C during the daytime, incidentally.Gundy1024 wrote:Ok, I changed the current setting according to SeeMeCNC down to 140,140,140,140,0. Did the same print in the same color and it printed, motor is still getting warm but not near as bad as it was before. Now I just need to figure out this stringing issue and I should have this thing tuned pretty good.
