Extrusion fails
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
Deltacon, that was my original problem back when I first built this printer. Had to call Seemecnc to get the correct motor current setting and have since then not had any problems with the motor getting screaming hot.
I have adjused the retraction setting as Xenocrates said and so far have produced two flawless prints. Trying the same model again but with 5 copies instead of one at a time to see if the longer print time causes the problem to come back.
Rostock Max V2 - Unnamed as of yet...
Robo 3D R1
One of the two printers can be found streaming at the link below just about every day. :)
https://www.youtube.com/watch?v=wky8RuNW9TY
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
If you use this link https://www.ustream.tv/broadcaster/20572527" onclick="window.open(this.href);return false; you can see it working. I have my better camera running tonight for this print.
Robo 3D R1
thedoble
Re: Extrusion fails
Post by thedoble »
The retraction speed of 110mm/s is very high. That may be enough to strip a 'groove' out of the filament, after which point the teeth can't grip any more.
I run 40mm/s retraction, with a length of 5mm on my e3d lite 6
Check the extruder temp again to be safe - if you can't hold your hand on it, it's too hot IMO.
Smoke me a kipper, I'll be back for breakfast.
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
Ok, so the long print from last night finished without any problem. Not going to say the new setting are the fix yet. I want to run so more test models with different infill and shapes. But it is looking good so far.
Robo 3D R1
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
Well just when you think all is good the problem returns.
Robo 3D R1
Windshadow
Re: Extrusion fails
Post by Windshadow »
Have you tried using the customer service chat function at https://seemecnc.zendesk.com/hc/en-us" onclick="window.open(this.href);return false;
look in the lower right corner of the page to activate it
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
I have not. Will give that a try tomorrow. Thanks
Robo 3D R1
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
Poor printer is at home just running away extruding nothing. Have to wait till it in get off work till I can stop it. :(
Sad to watch on ustream.
Robo 3D R1
barry99705
Re: Extrusion fails
Post by barry99705 »
Gundy1024 wrote:Poor printer is at home just running away extruding nothing. Have to wait till it in get off work till I can stop it. :(
You need to throw teamviewer on your pc so you can remote in and stop the print. It's free for personal use, you'll just get a "Brought to you by TeamViewer" pop up when you disconnect, no biggie. They even have clients for android and I believe iOS, so you can hit it from your phone.
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
Ok guys, new question on this problem. I have been feeding 100mms of filament through the hot end and what I have noticed is that it slows down and speeds up during the 100mm test. What could be causing this?
Robo 3D R1
thedoble
Re: Extrusion fails
Post by thedoble »
Very odd ...
I would have to say faulty stepper / controller or interference somewhere.
The amount of torque the steppers put out far outweighs the amount of friction, so there's no way it would slow down, other stuff would break first (filament would slip etc)
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
Yeah, I am at a loss here. Going to try and get a hold of SeeMeCNC today.
Robo 3D R1
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
OK, want to talk about frustrating. Got a hold of SeeMeCnC today via the live chat. Got the printer printing and would it fail? NO! Started another print for him and that print is still going strong. Guess I will be chasing my tale for a while till this problem decides to come back... :P
Here is the link to watch this print. https://www.ustream.tv/broadcaster/20572527" onclick="window.open(this.href);return false;
Robo 3D R1
DeltaCon
Re: Extrusion fails
Post by DeltaCon »
So essentially you have to keep the SeeMe Chat opened during print... ;-)
You don't want to know how many IT problems I solve daily just by listening to customers explain them. Problems solve automagically once the have me on the phone! :roll:
Re: Extrusion fails
Gundy1024 wrote:OK, want to talk about frustrating. Got a hold of SeeMeCnC today via the live chat. Got the printer printing and would it fail? NO! Started another print for him and that print is still going strong. Guess I will be chasing my tale for a while till this problem decides to come back... :P
You must have chatted with John Oly, I have heard that he can work miracles.
barry99705
Re: Extrusion fails
DeltaCon wrote:So essentially you have to keep the SeeMe Chat opened during print... ;-)
I hate it when that happens. Usually requires another callout... :roll:
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
So a new clue in the on going troubleshooting has come to light for me. Not sure why I did not notice this earlier but the problem of the extrusion jamming seems to be happening between prints. If I start a print with a fresh cut filament the print works fine. Once the hot end cools off and I try again this is when the clogging/jamming happens. If I pull the filament out and start with a fresh cut every time it has been working fine. Anyone have an idea why this is and how to fix it? Could it be a bad end on the Bowden tube in the hot end?
Thanks as always for you input.
Robo 3D R1
DeltaCon
Re: Extrusion fails
Post by DeltaCon »
Does your peek fan shutdown before the hotend gets below 50 degrees?
The standard firmware from SeemeCNC is setup to keep the peekfan running intil it droppes below 50 degrees C.
Therefore you must also not power off your machine until the fan stops on it's own.
Gundy1024
Re: Extrusion fails
Post by Gundy1024 »
I am running an E3D print head. The cooling fan for it runs at all times.
Robo 3D R1
