Oh Ohh...0110-m-p wrote:So I finally got my build platform "flat enough" with a max deviation (high-low) of 0.004". I optimized the calibration the best I could and ended up with a range of +0.0015/-0.0025" when the center is at zero. This is opposed to the more natural +0.000"/-0.004" that happens when using the X,Y,Z, center height = 0 calibration only.
It is odd the way I improved it though since I couldn't get any better with software changes or end stop screw settings. I ended up playing with where I put the glass build plate clamps and the size of clamps used. I used two small clamps on either size of the heated bed wiring next to the Z-tower, one large clamp directly inline with both the X and Y towers, and no clamps at all in between towers.
I still don't understand how the height can be correct based on X, Y, and Z-towers, but not based on the same points between the towers with equidistant build plate clamping. On my machine, I was consistently calibrating to zero on the towers and center and it would be 0.003", 0.005", and 0.012" low between all towers (calibrated tower rotations so that no spots were high). For some reason I also couldn't get the spot opposite the Z-tower to not be the lowest point. Just hate having to configure clamps on the bed to get it level rather than being able to get it correct in software.
That sounds familiar.
1) At one point I had TWELVE small binder clips around the plate and things got a bit weird.
Long story short, I misplaced one of the original six and the easy way to buy one was to buy a dozen - it SEEMED like a good idea to use them all in an attempt to clamp that glass down FLAT.
2) The O/P of this thread posted a procedure for leveling and shimming the snowflake BEFORE clamping the glass to it.
Now, I do KNOW (from other "life experience") that glass is "kinda bendy" (a technical term meaning flexible) so I wonder if we are dealing with bed flatness or if we are trying to "follow the bend(s) in the glass".
I am tending toward "shim the snowflake first" - - I am also thinking that measuring for "flatness" with the glass merely ON the snowflake, not clamped, would be worth while.
I have another variable, a thin sheet of aluminum as a heat spreader.
I looks flat, but I suspect that there are stresses in it from having been in a roll when I bought it.
