![Crying or Very Sad :cry:](./images/smilies/icon_cry.gif)
I've had my RMv2 for 5-6 weeks now, and I have spend the last three weeks trying to get rid of stringing with PLA. This is the best my printer can produce:
I feel like I've tried everything:
* Tried every temperature ranging from 160 to 210 degrees.
* Tried four different kinds of PLA
* Tried every extrusion multiplier from 1.1 down to 0.50.
* Tried Z-lift from 0.2 to 6 mm
* Tried with and without Wipe
* Retraction speeds from 25 to 100 mm/s
* Retraction lengths from 2 to 10 mm
* Slow and fast print speeds
* Small and large layer heights
* Tried Slic3r, KISSlicer and CURA
* Cleaned the extruder
* Lubricated the Bowden and nozzle with Canola Oil (yes, Canola Oil... https://groups.google.com/forum/m/#!top ... 5-false%5D" onclick="window.open(this.href);return false;)
* Polished the outside of the nozzle (thinking that the PLA might stick to the outside of the nozzle)
* Machined my own nozzles with different orifice diameters and lengths
* Machined a new PTFE liner
NOTHING helps
To start somewhere I have a few questions, which you are probably able to answer:
1. I took the hot end apart (again) to check the PTFE liner. Does this liner seem wrong to you?
2. When I assembled the hot end, I noticed that the nozzle is not completely perpendicular to the heated bed. I took the hot end apart again, and it seemed that the threaded part of the PEEK is a bit "crocked". Does this PEEK look wrong to you? Will issues with a molten PEEK result in stringing?
3. I have found that I have to print at about 175 degrees (the first picture was printed at that temperature). Isn't that kind of low?
4. I also see a lot of oozing. Is this related to stringing in any way?
5. By accident I found that if I turn the layer fan completely off, I get no stringing (??). Of cause that is not feasible, because the object will look awful. Any thought on that? What is actually the effect of too much cooling?
Please, answer any question you can - I really need all the help I can get
