I recently inherited a RostockMAxX V1 (I believe) from a good friend who is moving across country. On startup, the display briefly flashes "Repetier 0.83SeeMe RostockMAX". I tried to figure out exactly what I'm working with based on what I can find on the SeeMeCNC site, and I have to assume it's just a very old model. The display is in the base, the top is a single plate, connection is via USB cable (that terminates inside the base of the machine, though that could be just how my friend built it), and the majority of the device is comprised of laser cut phenolic ply (or similar). I'm very new to 3d printing (this is my first rodeo for sure), but not entirely new to the genre. I was able to get it up and running, and mostly printing, just not very well. If I had only one problem, I think I could figure it out, but I'm fairly certain I have a wide range of issues making for a difficult to interpret solution.
Issue the first: using bright green filament (very old, but from a sealed bag with desiccant in a dry Colorado winter), the resulting print came out brownish green and banded (the intended shade of green and the brownish green). I interpret this as the nozzle getting too hot, then cooling down. There is a fan on the extruder, and it does not come on. I'm not sure if it's supposed to come on though, so may or may not be an issue (call it "issue the first-sub-b"). The machine sat in a garage for a few years, and had accumulated a lot of dust. I cleaned it prior to any use, but there was a noticeable amount of dust in the filament tube. It may have contributed (there were other issues), so I cleaned the nozzle (acetone, then torch). Using MatterControl, I dropped the temperature of the nozzle, and was mostly able to get this problem to go away, but by the time it went away entirely, I seemed to be having cold issues...
Issue 2: The scale seems off. 1mm in MatterControl was substantially less than 1mm in the printed object. I manually scaled things for the test print, figuring I could address this issue once I get a handle on some of the others.
Issue C: Once I got the scale sorta figured out, it got 90% of the way through a 2 hour print (during which I was in another building doing loud hot things), and just stopped. There was no obvious anything. MatterControl just sat there. I'm pretty sure it was still connected, and I think what ultimately happened was I killed the print from there. Obviously the part wasn't finished, but also there was a burned spot with a big oozy booger where the nozzle stopped and sat for some unknown amount of time.
Issue ∏: I decided to back off a step, and try to troubleshoot some of this with a less filament intensive object. I modeled a 1cm cube, and got to work trying to solve issues there. X and Y axes were about 5% too small (too much to account for ABS shrinkage), and Z was long. This sorta goes back to scale, but advances the story in that there are different scaling errors in different directions.
Issue V: The corners of the cube were pulled up. I increased the bed temp, but it didn't seem to affect anything in a positive way. I read immediately prior to starting this thread that models under 15mm may not have enough time to cool, so this could be it. I dropped the nozzle temp all the way down to 220°C (by which point the browning has mostly, but not entirely gone away), but then I started having cold issues AND the corners were curling.
Issue (Prince symbol): Seemingly no matter what I did in terms of z-distance to the bed or temperature, 100% fill would not result in infill meeting sides...
issue that's barely an issue: Calibrating the bed level did not result in the nozzle being able to touch the bed in a few places. It's such a low priority and likely easy fix that I hesitate to even mention it, but I figured I'd toss it up here for completeness since it came to mind while I was typing this. It may be all to one side or something simple like that, but again, with everything else it's a very low priority.
There are probably other issues that I'm forgetting or don't even know are issues yet... I'd love to be able to get this thing to work and printing usable parts. I struggled for years to come up with a way to use a 3d printer in my other adventures, and now that I have one I can't stopping thinking of things to do with it. I'm eager to start making things!
RostockMax V1 + noob + lots of issues and not sure where to even begin
- Plasticator
Re: RostockMax V1 + noob + lots of issues and not sure where to even begin
Issue C, I assume you were printing the file from your PC, not the SD card? If that's the case, load the file onto the SD card and try again. Your PC may have went into some sort of power saving mode, and interrupted the print.
- Plasticator
I had a similar suspicion, and adjusted power settings, etc. accordingly. Haven't managed to get that far into a print since though... I don't recall seeing an SD card slot anywhere on the exterior of the machine... Where would it be?
Here's where you should be able to find a manual to determine what you have,,,, and if it's rocking the original RamBo board, where the sd card slot is located. https://www.seemecnc.com/pages/downloads
- Plasticator
That link is a 404. I figured out where you intended, and the manual shows something different than what I have.
I looked at the documentation page, and the documentation doesn't go back far enough. I haven't found a photo of any machines that look much like mine. On page 216, there's a photo of the "Blue Max". Mine looks most similar to that (though there are still a number of differences). The phenolic ply is uniformly colored the dark brown phenolic ply color all the way through. Another difference that stands out is how the extruder is mounted. I'll try to take photos of the machine this afternoon.
I didn't notice that the front opens, but I'll check that out and see if I can find an SD card.
The initial post was getting everything on the table. I'm going to try to get a little deeper here and ask more specific questions.
Issue the first/sub b: When/is the fan supposed to come on? What triggers it? I might have an idea if that warrants investigation if I know what it is expected to do, when, etc.
Issue 2: I need to do some calibration prints, and from there should be able to figure out the scaling. It looks like I can handle scaling on a case by case basis in MatterControl, but I may also be able to do some PID tuning. The latter assumes I have more of a clue than I do, but from what I gather, if I'm so many percent off in a particular axis, I should be able to scale that axis accordingly and solve the scaling issue. Is it better to adjust this in MatterControl or via PID tuning (also through MatterControl)?
Issue C: This was likely a power issue on my laptop. Easily resolved. If that's not what it was, I won't know until I get much further along, at which point this can be revisited.
Issue ∏: I just realized this is the same as Issue 2. Disregard.
Issue V: I found a link to an .stl file in the manual referenced above to a calibration cube. It's 25mm on all sides. That dovetails with the premise that objects under 15mm may not print well because the plastic doesn't have time to cool between layers. I'll use this going forward, and this may resolve that issue.
Issue (prince symbol): Still no plan of attack for this one.
Issue that's barely an issue: This is such a low priority that I'll get to it when I get to it.
- Plasticator
[img]https://photos.app.goo.gl/Ma8QURJMvEL2Jwj59[/img]
[img]https://photos.app.goo.gl/LJqTopH91fKfqri6A[/img]
[img]https://photos.app.goo.gl/P82C5yd8Qt8gci1q9[/img]
[img]https://photos.app.goo.gl/RaZ16E9BZYkYVYB39[/img]
Sorry for the weird links... Open in a new tab, and remove the seemecnc generated parts of the URL. I can't figure out how to make them post correctly, and not for lack of trying all the permutations I can think of for posting on these pbb forums...
I lied slightly. The phenolic ply is black on the outer layers. It just seemed phenolic brown because it was reflecting the oak of my desk...
At any rate, once I realized it opened I figured out how to open it, and found the SD card hiding under the edge of the plate holding down the display panel.
I see that the forum is adding trash to links to make them inoperable,,,,,, This place has turned into a ghost town. I am surprised that GeneB hasn't popped in, as he had written most of the manuals.
Now that you found the SD slot, try a long print with using that,,,, If It still shuts down, I would be suspicious of the power supply. SeeNeCNC has pretty much switched over to the industrial power supplies instead of repurposing the pc power supplies.
That hotend is a workhorse, but the weak link with it is the use of resistors for heating elements, GeneB has a youtube video showing how to replace them with a heater cartridge.
- Plasticator
Yeah. Not the hoppin'est juke joint in town for sure. When I dive down these rabbit holes, I typically look for the most active forum. This particular machine is not the most common out there though, and since I'm still not even sure what version it is it's hard to get super specific.
Long story short, I can't be where the machine is for any length of time until the weekend at the earliest (no water, but not for the reasons in the news). My plan of attack at this point is to see what's what in terms of adjusting the bed on the low end just to get a win in the form of some low hanging fruit. Then, I'll print the hollow cube from the manual at that larger scale and see what I can see about the temperature settings. I've been dropping the heat in the hot end and raising the heat in the platten, and it may just be due to the small scale of the test object. If, at the larger dimensions, the corners are able to cool enough to stop curling, I'll be fighting one less variable to get the temperatures dialed in. Temps likely represent a good chunk of my problems.
I still don't know what the software is calling for on the fan though. When/should it be coming on? Now that I've figured out how it opens up, I could conceivably check for voltage at the board (following the extruder with a pair of probes seems like folly).
I think the step after that would be to either scale the model, or dive into PID tuning. I'm a little concerned that proportionally adjusting the stepper motors will be challenging given the geometry of it... Are there any guides for this? It's a lot more complicated than simple X/Y/Z axes (or is it?). Would it just be simpler to write down a scale factor or something, and adjust every single model that comes through (this seems like a hacky solution, but if PID tuning isn't feasible with the geometry of it, it is what it is)?
It appears that you have the V1, Myself I have the V2, PID tuning was only used for adjusting the hoteend, and yes, delta geometry makes calibrating the axis travels a totally different animal. If you download the pdf manual for the V1, from the download page, and go about it as if you're building the machine, you will find out about the initiall setup, and calibration routines. From there, this forum has a wealth of information about fine tuning the printer.
There is a Facebook, SeeMeCNC group, but you wold prolly be better off doing searches on this site. Page 152 is where you would find the software installation and confuguration
