Hey everyone, I have a new Rostock max V1 and having trouble uploading the firmware. no instructions that I can find. BUT
can i use the instructions from the version 2 manual? Are the settings the same? i have the ez exstruder and top filament mount.
Thanks
new version 1!
Re: new version 1!
The instructions should be correct for the upload process. However, the calibration values such as the horizontal radius, and diagonal rod length, will be incorrect. There may be references in the code, or one of the people who've owned a V1, such as Geneb or Proto, could help you. Alternatively, you can upgrade the carriages and arms (I recommend this anyways). The thermistor values may also be incorrect.
