I have made some changes to my printer within the last week. I added a titan extruder (no issues after that mod) and then a PT-100 temp sensor this last weekend (has been working fine till tonight, to the best of my knowledge, but I may have had things preheated before I started the last several prints due to changing filament types/rolls).
To get the PT-100 working I hooked it up to the analog 3 pin and changed the ext0 temp pin to 3 in config.h. I then swapped the thermistor 1 table in the extruder.cpp file to a pt-100 specific table I found elsewhere on this forum. and finally changed the ext0 temp sensor type to 1. Everything is working great as far as heating up and holding temp nicely, etc...
The only wonky thing is what it did tonight. The only other thing of note I did this evening before the issue popped up was to setup Octoprint on a different computer. The printer went a little goofy on me and I had one crash. After I reset, reconnected, and rehomed is when I started noticing the temp issue. Since then I've tried reslicing with slic3r, printing older gcode files (that I know were good), printing from simplify3d, printing from the SD card with USB Cable attached and unattached at the board and pc, reflashing the firmware. getting a stock version of 92.2 firmware and tweaking the few necessary settings only. Clearing eeprom and flashing again. (tried with 1.6.0, 1.6.1, and 1.8.5) Same result with everything. It's almost like something maybe went haywire on the board itself, but I wouldn't have a clue what, since everything else seems to be working good
here's the gcode readout I got during one of the attempts:
READ: T:24.37 /0 B:49.27 /50 B@:255 @:0
READ: T:24.37 /0 B:49.32 /50 B@:255 @:0
READ: T:24.69 /0 B:49.46 /50 B@:202 @:0
READ: ok
SENT: M105
READ: TargetExtr0:235
READ: ok
READ: T:24.37 /235 B:49.50 /50 B@:255 @:255
READ: T:24.37 /235 B:49.55 /50 B@:255 @:255
READ: ok
SENT: M105
SENT: G28
SENT: G1 E-6.5000 F6600
SENT: G1 Z0.525 F1200
SENT: T0
READ: T:25.00 /235 B:49.60 /50 B@:189 @:255
READ: ok
READ: ok
READ: SpeedMultiply:100
READ: X:0.00 Y:0.00 Z:355.800 E:0.0000
READ: ok
SENT: G1 X-67.370 Y-11.309 F9000
SENT: G1 Z0.225 F1200
READ: ok
SENT: G1 E6.5000 F1980
I'm trying a slic3r print through octoprint atm with some known settings just to make sure that's the only issue I'm having and it looks like the extrusion might be a little inconsistent compared to what it normally is. Hopefully these aren't signs of a dying board? Any thought's or suggestions on what might fix it?
