Ive been trying for days trying to figure it out and its extremely frustrating because i know how amazing this setup (duet wifi and fsr with trick laser plate) should be but i feel like im missing something. I will attach the bed height map and a photo of my first layer to see if someone can help me out. my auto calibration returns a consistent deviation of .02 and i have checked the trigger height of my fsr across all the probing spots for the auto calibration. This ranged from -.180 near fsr to -.265 max. the center of z had a trigger height of -.242 which im using as a z offset. Should i instead use a average of all the trigger heights ive calculated and use that as my z offset?
; Configuration file for SeeMeCNC Rostock MAX V2
; Communication and general
M111 S0 ; Debug off
M550 PSeeMeCNCRostockMAXV2 ; Machine name and Netbios name (can be anything you like)
;*** Wifi Networking
M552 S1 ; Enable WiFi
M555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Comms parameters for PanelDue
G21 ; Work in millimeters
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
; Axis and motor configuration
M569 P0 S1 ; Drive 0 goes forwards
M569 P1 S0 ; Drive 1 goes forwards
M569 P2 S1 ; Drive 2 goes forwards
M569 P3 S1 ; Drive 3 goes forwards
M569 P4 S1 ; Drive 4 goes forwards
M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
M665 R143.685 L290.8 B120 H380.91 X-0.168 Y-0.300 Z0 ; set delta radius, diagonal rod length, printable radius and homed height
M666 X-0.38 Y-0.38 Z0 ; put your endstop adjustments here, or let auto calibration find them
M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
M92 X80 Y80 Z80 ; Set axis steps/mm
M906 X1000 Y1000 Z1000 E1000 I60 ; Set motor currents (mA) and increase idle current to 60%
M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
; Thermistors
M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B4725 R4700 H30 L0 C7.06e-8 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
;M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
; Fans
M106 P1 H-1 ; disable thermostatic mode for fan 1
; Tool definitions
M563 P0 D0 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
;*** If you have a single-nozzle build, comment the next 2 lines
;M563 P1 D1 H2 ; Define tool 1
;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M92 E91.4 ; Set extruder steps per mm
; Z probe and compensation definition
M558 P4 X0 Y0 Z0 ;H5 F1200 T2400
; grid compensation
M557 R80 S6
G31 X0 Y0 Z-0.238 ; Set the zprobe offset and threshold (determine your printer's Z offset value). For a delta, use zero X and Y offset.
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation here
T0 ; select first hot end
M501 ;uses override calibration settings
