I looked at how heated chambers have been managed in the past, and didn't exactly like the way that they used external controllers. I would prefer to use something which I can just select a file and let it run. As I know I can redefine pins, such as adding a heater for a hotend without a stepper, and all rambos have 4 thermistor inputs (of which I am using one, since I have a PT100 for my hotend), and yet lack a 3rd extruder stepper port, it would only be logical to try putting the chamber heater control on the Rambo. As I had a relay designed to switch wall voltage, and it would accept the signal voltage from the Rambo, I figured there's nothing to lose trying it. I'm rather busy recently, so I'll be testing it over an extended period. But I figured I'd get some of the info out there, and let people know if there are problems.
So without further ado, a picture of the abomination thus far:
I'll keep this thread updated with progress and problems. And before anyone asks, yes, that is a 400W infrared bulb. I am aware it's huge and may cause issues. I will be testing it pointed at a spare piece of polycarbonate before I install it. If it's too large or powerful, I am debating between other smaller heat lamps, and one of the ceramic IR emitters. If it works, then I have successfully managed to make the chamber heater more powerful than anything short of a 24V bed. Should solve my bed temperature issues, and low ambient temps.
