You have the adapter, I do not so to use the Bondtech as a bowden on the output the insignia would be upside down.mhackney wrote:If you order on the BondTech site, it is pointed out that you need the adapter for Bowden usage. I can't speak for the US distributor as I have not looked at their site.
None of the insignias are upside down on mine, is yours?
I wrote the previous message to help others that buy the Bondtech to be sure to buy the adapter.
Does the adapter require one of the press in Bowden connector or can you use a screw in?
