Sketchup STL export plugin
http://www.sketchup.com/
joerlane
Post by joerlane »
I found this plugin to export STL files from Sketchup useful. Just drop it in the plugins folder and an extra option appears in the Tools menu to export DXF or STL. The STL files I have exported worked fine with skeinforge.
[url]http://www.guitar-list.com/download-softwar ... dxf-or-stl[/url]
lynx74br
Re: Sketchup STL export plugin
Post by lynx74br »
A good example: [url]http://www.thingiverse.com/thing:19414[/url]
johnoly99
Post by johnoly99 »
Nice job lynx, I actually printed a few of those as did Brianvandiepenboss for his machine I believe
@CiDG
Post by @CiDG »
This is the plugin I use. I struggled with it on some of my drawings because I use inches when I make my models. Be sure to convert to Millimeters before exporting to avoid exporting an STL file that will contain a microscopic model. You can tell you did this when your gcode files are small (4k to 15k or so) and the prints look like 1/4" blobs or curly Q's.
Even if you export in inches this will happen. You could rescale it in Slic3r, but the fix is simple enough in SU.
bvandiepenbos
Post by bvandiepenbos »
Hi Oly, yes I have those printed belt clamps on my machine. works well.
Thanks lynx
~*Brian V
johnoly99 wrote:Nice job lynx, I actually printed a few of those as did Brianvandiepenboss for his machine I believe
lynx74br
Post by lynx74br »
I'm happy that it helps someone.
I have made an OpenSCAD version, it is easily changed for others sizes. Sketchup is not intuitive when you need it.
lynx
Return to “Sketchup (formerly Google Sketchup)”
