V4 / Duet2 / KISSlicer / DUAL EXTRUSION Y-bowden FEED and RETRACT?
Posted: Fri Jul 26, 2019 5:23 pm
V4 set-up as above
KISSlicer Premium v1.6.3
I have dual enabled in the Duet config
Bear with me here, I've had multi-extruder KISS for one day, and this is my first dual extrude.
How the heck do you get the filament to feed and retract?
I just don't know where to start with the whole retraction/feed issues
According to the SMCNC CURA setup you pull the filaments away from the Y-connector 40mm to start.
This would imply that something then tells the machine to push/pull the filaments accordingly.
Help me make a new SMCNC Guide for KISS community!
NO idea if I need to modify KISS, Duet config, or BOTH?
I've got KISS generating a test with short pillar:
Guessing magic has to happen here: and here:
CAN SOMEONE PLEASE POINT ME IN THE RIGHT DIRECTION/S?
There must be some documentation somewhere on how this is achieved as you guys have been doing multi-extruder prints for at least 2years, right?
Hopefully I can lure Hackney(HA!)
get it?
cast,
tug, tug, tug
Thanks in advance!!
UPDATE:
I got the Printer and Extruder settings from SMCNC for CURA, so if I put them into KISS correctly they should work(?)
Can anyone point out the correct KISS locations for these? per email:
The code in the machine settings(first pic) is where the filament prime, retracts, and at the end retract back so both filaments are above the Y are set up.
I've got this so far:
get it?
cast,
tug, tug, tug
Thanks in advance!!
UPDATE:
