Hotend cooling during filament change?
Posted: Fri Mar 26, 2021 2:36 pm
by d1rron
I'm trying to print the SeeMeCNC articulated bat, but when it switches to the second filament it throws an error because the hotend starts cooling off and then it stops extruding which is nice. Someone on the Facebook group said I need to edit the GCode manually for dual extrusion, which is fine, but I'm not sure how to. Here's the beginning of my Gcode: Image
I kind of assumed I needed to copy the T0 and make a T1, which is roughly what was suggested, but I just want to make sure I'm making the correct changes.
Re: Hotend cooling during filament change?
Posted: Fri Mar 26, 2021 2:58 pm
by d1rron
Well I got an answer that my hunch was correct and that I just need to copy T0 and rename that one to T1. Leaving it up in case anyone else has the same question.
Posted: Sat Mar 27, 2021 12:34 pm
\o/
