Slicing with F360
Posted: Mon Aug 17, 2020 11:54 am
by durian
I'm relatively new to Fusion 360 (I come from the electronics side with EAGLE) and even newer to 3D printing. I see that F360 has support for slicing. I thought I might experiment with it since I'm using it for design work, but it looks like you need to do some printer-specific setup. Has anyone used F360 for slicing? Do you have printer setup information you could share (RMAX4)? What do you use for post processing (generating the G Code)? They've got a generic option, but I'm sure it would have to be tweaked to with with the SeeMeCNC printers.
mike
Re: Slicing with F360
Posted: Tue Aug 18, 2020 8:20 am
You'd be much better off using Cura I think.
Posted: Wed Aug 19, 2020 5:37 pm
by durian
Hi geneb,
Are you speculating or did you actually try Fusion 360? If you did give it a spin, do you have setup and post processor configurations you could share?
Posted: Thu Aug 20, 2020 7:56 am
by Mac The Knife
Autodesk had just released the 3D printing capability just a few months ago, so the availability of a setup for the SeeMeCNC machines are nil. I played with the module a couple times to check out the interesting infills that they offer, but at initial release it was not quite there. I'll have to try it again and see how it works.
As for a profile, if you take your time, you can tweek a generic profile for your machine, just be prepared to hit the cancel button. I set mine up for a FT-5 printer, not a delta, so it wouldn't do any god to share it with you.
I use Fusion 360 for most of my modeling, and have it set up to send files that I want to print to my slicer of choice,,,, which is Simplify 3D.
Posted: Thu Aug 20, 2020 2:30 pm
by durian
Thanks, Mac The Knife. I guess I'll experiment with rolling my own.
mike
Posted: Fri Aug 21, 2020 8:22 am
Keep in mind that Cura is purpose-built for the task it does and it's very, very, very, good at what it does. The slicer in F360 is a bag hung on the side as a "feature". Yeah, it'll probably get the job done, but not nearly as well as a dedicated, purpose-built slicer. If you don't like Cura, there's other options like Prusa Slic3r, KISSlicer, etc.
