Delta Calibration Wizard now online
Re: Delta Calibration Wizard now online
Yeah I contacted support over lunch and Ryan suggested the same and to try it again basically. So I went through the wizard for the 4th time and of course that time it worked as expected.
The results also fixed my bottom layer problems too!
fj..
fj..
I have a Max V2 with upgraded arms from Brian. What would I have to do to add this capability to my machine?
I assume I would need the accelerometer board and newer software in my Rambo... And then mount my head in that new board?
Brynn
Brynn
The accel board and newer firmware are the bare minimums for this all to work.Tonkabot wrote:I have a Max V2 with upgraded arms from Brian. What would I have to do to add this capability to my machine?
Brynn
If your TrickLaser arms are a different length than stock though, know that the octoprint plugin won't work for you.
My tricklaser arms are whatever the standard length they come as, I assume that is same as the original arms... I don't know.
What is the Octoprint plugin? what software does it plug into? I thought the Octoprint stuff had something to do with a raspberry Pi.
Brynn
Brynn
- Plasticator
Hi guys,
It was a long time that i didn't came here and just see this.
I worked on a similar project few times ago and did my own full automatic calibration, based on the esher3d calibration wizard (wich look exactly the same as this wizard).
I'va add a g135 command that do all 10 point probing, 2 times probing on each point then average of this 2. After the 10 points are probed it send back the result in the console. Here a plugin in Octoprint read the result and calculate the modifications, send back the result to the printer. All this loop as long as all value zprobe are over a defined value (0.03 for me) with a maximum of 10 passes.
If anybody is interested by my work, let me know, i will try show exactly all what i made (if i all remember because i did it in december 2016)
Here is a video of a calibration on 3 passes :
[url]https://www.youtube.com/watch?v=m80Zn_BZKsg[/url]
Please tell me more about your work. How to run the G135 for example.
I'd be curious to see how it compares to the delta calibration plugin that I wrote based on dc42's original javascript calculator.
Was your code in the firmware?
tnx!
tnx!
- Plasticator
Based on the G29 command i have created a new function named "tapZProbe" like this :
This function make 2 "tap" at the position given in argument and give back the average of this 2 taps results.
After this i have created the new G135 command, this command will do all the 10 positions probing, then write the result as a block of text in the console, with all the parameter needed for the calculation (rod length, towers offset etc...).
after this I have first modify the form of the wizard that i don't need to put every value one after one, i had just to put the block of text and the javascript split all to find the needed values, but after few weeks i decided to make an octoprint plugin to replace this wizard.
ps : sorry if my english is a little bit weird, this is not my natural language
float tapZProbe(float x,float y)
Com::printF(PSTR("Probing x: "),x);
Com::printFLN(PSTR(" | y: "),y);
float sum1 = 0, sum = 0, last,oldFeedrate = Printer::feedrate;
int32_t probeSensitivity = Z_PROBE_SENSITIVITY;
bool failedProbe = false;
do {
Printer::moveTo(x,y,IGNORE_COORDINATE,IGNORE_COORDINATE,EEPROM::zProbeXYSpeed());
sum1 = Printer::runZProbe(true,false,Z_PROBE_REPETITIONS,false); //First tap
sum = Printer::runZProbe(true,false,Z_PROBE_REPETITIONS,false); //Second tap
if ((sum1 - sum) > Z_PROBE_TOLERANCE || (sum1 - sum) < - Z_PROBE_TOLERANCE){ //tap reports distance, if more or less than .1mm, it will re-run
Com::printFLN(PSTR("Z probe failed on sensitivity: "), probeSensitivity );
if(probeSensitivity < Z_PROBE_MAX_SENSITIVITY){
accelerometer_recv(0x32);
probeSensitivity+=2;
Com::printFLN(PSTR("Setting Probe Sensitivity To:"), probeSensitivity );
accelerometer_write(0x32,uint8_t(probeSensitivity)); //INT1 THRESHOLD
accelerometer_write(0x3A,uint8_t(probeSensitivity)); //CLICK THRESHOLD
sum = -1; failedProbe = true;
continue;
}else{
sum = (sum + sum1) / 2; failedProbe = false;
}while(failedProbe);
return (sum - Z_PROBE_BED_DISTANCE);
case 135: // G135 3 points, build average or distortion compensation
float results[10];
Com::printFLN(PSTR("auto bed level"));
if(com->hasI()){
// Parameter I initialize all to défault parameters
EEPROM::setDeltaTowerXOffsetSteps(0); // set X offset to 0
EEPROM::setDeltaTowerYOffsetSteps(0); // set Y offset to 0
EEPROM::setDeltaTowerZOffsetSteps(0); // set Z offset to 0
Printer::radius0 = 144;
Printer::zLength = 365;
EEPROM::setdeltaAlphaA(210);
EEPROM::setdeltaAlphaB(330);
EEPROM::setdeltaAlphaC(90);
EEPROM::setdeltaDiagonalRodLength(290.8);
EEPROM::storeDataIntoEEPROM(); // store offsets to 0 before doing anything
EEPROM::readDataFromEEPROM();
Printer::homeAxis(true,true,true);
GCode::executeFString(Com::tZProbeStartScript);
Printer::setAutolevelActive(false);
//Plateau réduit cage plexi, rayon 130
results[0]=tapZProbe(0,130);
results[1]=tapZProbe(112.58,65);
results[2]=tapZProbe(112.58,-65);
results[3]=tapZProbe(0,-130);
results[4]=tapZProbe(-112.58,-65);
results[5]=tapZProbe(-112.58,65);
results[6]=tapZProbe(0,65);
results[7]=tapZProbe(56.29,-32.5);
results[8]=tapZProbe(-56.29,-32.5);
results[9]=tapZProbe(0,0);
Com::printF(PSTR("IP: "),Printer::zLength);
Com::printF(PSTR(" "),Printer::radius0);
Com::printFLN(PSTR(" "),EEPROM::deltaDiagonalRodLength());
Com::printF(PSTR("ES: "),EEPROM::deltaTowerXOffsetSteps());
Com::printF(PSTR(" "),EEPROM::deltaTowerYOffsetSteps());
Com::printFLN(PSTR(" "),EEPROM::deltaTowerZOffsetSteps());
Com::printF(PSTR("AN: "),EEPROM::deltaAlphaA()-210);
Com::printF(PSTR(" "),EEPROM::deltaAlphaB()-330);
Com::printFLN(PSTR(" "),EEPROM::deltaAlphaC()-90);
Com::printFLN(PSTR("P0: "),results[0]);
Com::printFLN(PSTR("P1: "),results[1]);
Com::printFLN(PSTR("P2: "),results[2]);
Com::printFLN(PSTR("P3: "),results[3]);
Com::printFLN(PSTR("P4: "),results[4]);
Com::printFLN(PSTR("P5: "),results[5]);
Com::printFLN(PSTR("P6: "),results[6]);
Com::printFLN(PSTR("P7: "),results[7]);
Com::printFLN(PSTR("P8: "),results[8]);
Com::printFLN(PSTR("P9: "),results[9]);
GCode::executeFString(Com::tZProbeEndScript);
break;
- Plasticator
That's really slick! (and your English is just fine!
Have you thought about packaging that up so others could use it?
tnx!
tnx!
- Plasticator
To be honest i never did any package, and i even don't know how to do it. This code is free to take, i've done this fast and i'm sure that it can be improved. If anybody want try package this to do something better that's ok for me.
I will try to share the octoprint plugin as well, and the code of the wizard that i had modify, but for this last one i think i should give it to the admin who build the wizard here on seemecnc in private as mine came from esher (i'm not sure if i have the right to share it in public).
I've built the octoprint plugin to send the command g135 as long as all values are not under a defined range (0.04 in my case), with a limit of 10 (to avoid infinite loop).
I forgot to say that i had to build the M663 M664 and M665 command too as they didn't exist in the original firmware, these commands are to store the new values in the eeprom :
case 663: //M663 set X Y Z endstop
if(com->hasX()){
EEPROM::setDeltaTowerXOffsetSteps((float)com->X);
Com::printFLN(PSTR("Xstop changed to "),(int16_t)com->X);
if(com->hasY()){
EEPROM::setDeltaTowerYOffsetSteps((float)com->Y);
Com::printFLN(PSTR("Ystop changed to "),(int16_t)com->Y);
if(com->hasZ()){
EEPROM::setDeltaTowerZOffsetSteps((float)com->Z);
Com::printFLN(PSTR("Zstop changed to "),(int16_t)com->Z);
break;
case 664: //M664 set X Y Z Towers alpha
if(com->hasX()){
EEPROM::setdeltaAlphaA(210+(float)com->X);
Com::printFLN(PSTR("X Tower Alpha changed to "),210+(float)com->X);
if(com->hasY()){
EEPROM::setdeltaAlphaB(330+(float)com->Y);
Com::printFLN(PSTR("Y Tower Alpha changed to "),330+(float)com->Y);
if(com->hasZ()){
EEPROM::setdeltaAlphaC(90+(float)com->Z);
Com::printFLN(PSTR("Z Tower Alpha changed to "),90+(float)com->Z);
break;
case 665: //M665 set radius, rod lenght and home height
if(com->hasR()){
Printer::radius0 = (float)com->R;
Com::printFLN(PSTR("Radius changed to "),Printer::radius0);
if(com->hasZ()){
Printer::zLength = (float)com->Z;
Com::printFLN(PSTR("Home Height changed to "),Printer::zLength);
if(com->hasD()){
EEPROM::setdeltaDiagonalRodLength((float)com->D);
Com::printFLN(PSTR("Rod Lenght changed to "),(float)com->D);
if (com->hasR() || com->hasH()){
break;
The delta calibration wizard on dc42's site (http://www.escher3d.com/pages/wizards/wizarddelta.php) is open source as far as I know. That's what my Octoprint plugin is based on as well as the SeeMeCNC calibration page. If you're concerned about it, you can send him a pm here. He lurks here, so may show up. (I don't think he's the Beetlejuice type, we don't need to say "dc42!" three times..
- Plasticator
Hi,
I have upload my version of the calculator on Github if you want see how it was made.
https://github.com/avigeilpro/Delta_calibration
There are some few things to ajust :
I still work on the octoprint plugin to clean it before upload on github.
- In delta_calibration_wizard.js:
- the 10 probing points positions
- the bed radius
- the number of factors (numFactors)
- In upload.php
- the Octoprint IP
- the Octoprint API Key (defined in Octoprint settings)
Thanks for posting that!
