Rostock Max v3 only Duet upgrade?
Posted: Wed Jun 07, 2023 3:47 pm
by Francisco
Hello everyone!
After two years of my RMax v3 being in storage I saw the duet 2 wifi boards are really cheap now.
I was wondering, is it possible to only upgrade the board while mantaining everything else? I want to take advantage of the higher processing power the Duet 2 offers compared to Rambo.
I'm looking forward to give new life to this machine now that I'm moving to a new place with a small room separated from the house where the machines can work without disturbing my sleep.
Re: Rostock Max v3 only Duet upgrade?
Posted: Thu Jun 08, 2023 8:34 am
Having the Duet without either the SE300 or the Duet Smart Effector won't help you much. The huge benefit of the Duet is the auto-calibration that comes along with the strain gauge sensor that the SE300 and Duet Smart Effector use - it makes the nozzle tip a Z probe.
Posted: Tue Jun 27, 2023 8:49 pm
by Sonitrolio
I got the duet board and smart effector upgrade on my old V2. After some tweaking to get the settings dialed in, it prints better than ever.
Posted: Sun Jul 09, 2023 4:31 pm
by Francisco
Which one is the smart effector? I've got the stock RMax v3 extruder with the accelerometer probe. Should I buy a complete SE300 or could it be done cheaper?
Posted: Sun Jul 09, 2023 10:07 pm
by Sonitrolio
I don't know which one of the SeeMeCNC boards does the trick, but I got mine from duet directly...I dont think SeeMeCNC had theirs yet at the time.
Posted: Mon Jul 10, 2023 7:17 am
Apologies for the late response. Traveling.
If you want to supply your own hot end, like an E3D v6, you'll want the Smart Effector. If you want a plug & play solution, you should get an SE300 from SeeMeCNC - it's got the same strain gauge circuit as the Smart Effector, but also includes the hot end and layer cooling fans in one module. You can get a pre-built wiring harness for it as well.
If you're going the Smart Effector route, make sure you've got any 3D printed parts needed BEFORE you start your build.
Good luck!
