AstroPrint? Octoprint? Other?
Posted: Sat Oct 29, 2016 12:00 pm
by cloneit3d
Anyone running AstroPrint on a Raspberry Pi connected to a V3? I am trying to decide what to load on the Pi. Pros - Cons insights please.
Thank you,
Tim
Re: AstroPrint? Octoprint? Other?
Posted: Sat Oct 29, 2016 12:37 pm
by morgandc
Running Octoprint and love it. I pre-slice so I haven't used the integrated Cura engine much. Haven't tried any others options.
Posted: Sat Oct 29, 2016 1:30 pm
by cloneit3d
morgandc wrote:Running Octoprint and love it. I pre-slice so I haven't used the integrated Cura engine much. Haven't tried any others options.
Thank you- I loaded Octopi and have it up and running. I have only been able to run the calibration script g-code as I get an error when I try to run G-code generated from Matter. Maybe the start - stop g-code needs to be looked at.
Posted: Sat Oct 29, 2016 3:59 pm
by morgandc
I am slicing with Kiss, but used Cura fine as well.
Posted: Sat Oct 29, 2016 4:04 pm
What is the error? OctoPi shouldn't care what's IN the gcode even if it's wrong.
Posted: Sat Oct 29, 2016 5:51 pm
by lordbinky
I use OctoPi and slice with S3D. I like being able to check on it from my phone anywhere in the house. Now that I think about it I need to make a mount for the webcam but the empty can of duster works so well...
Posted: Sat Oct 29, 2016 9:24 pm
by cloneit3d
mhackney wrote:What is the error? OctoPi shouldn't care what's IN the gcode even if it's wrong.
Ended up the error said the bed sensor was defective so I checked it with an ohm meter and reseated the bed thermistor connection to the Rambo. Problem solved- for now.
