Rostock MAX v3...
KAS
Re: Rostock MAX v3...
Post by KAS »
sfuelberth wrote:So I just got mine delivered, however I am not seeing any sort of documentation. Is that still a work in progress or is there a link to them someplace that I am not seeing? Thanks
http://seemecnc.dozuki.com/c/Rostock_Max_v3
sfuelberth
Post by sfuelberth »
abecker
Post by abecker »
Lets see some build logs/pics!
Qdeathstar
Post by Qdeathstar »
Where is geneb's one
sfuelberth
I can post pics as it goes along, I had things come up this weekend though. I'll try and take some pics as we work through it.
sfuelberth
I'd like to say I know the manual is still a wip I love the animated parts. props to the documentation team, i'll probably have questions though.
Tincho85
Post by Tincho85 »
Yeap, loving the manual.
One thing I didn't notice before. Some steps have links to gene building it.
Martín S.
Tincho85
Post by Tincho85 »
One qustion, this is for tightening the belts? Pretty clever if so.
Martín S.
Yes. The stepper motor is now the belt tension adjustment. :)
Gene, are you working on your normal PDF instructions or is the one posted by JJ is all there is going to be.
I see no where I can download and print out the present docs, is there a way or we forced to be online while building.
Your assembly manuals were the best I have ever seen and they were also downloadable!
Please tell me if the technology has taken on a huge leap but the docs have taken a step backwards.
The Dozuki instructions are all that will be there - the only PDF docs that will remain will be a generic user guide for MatterControl that will cover all the printers.
Post by Mac The Knife »
So an internet connection is required at the time of building.
I'm pretty sure there's a "Download as PDF" link somewhere above the "Step 1" header...
geneb wrote:I'm pretty sure there's a "Download as PDF" link somewhere above the "Step 1" header...
If someone manages to find the "download as PDF" please tell the group where it is.
I for one do not feel you should have to have an internet connection to access the docs,
the old Docs were great, downloadable and printable. Like I have said before, 2 steps forward in technology
and two steps backwards on documentation. I am not complaining about the V3 docs; I am complaining
that they are not downloadable and thus not printable.
Right below the "Files" section, there's a bit that says "Formats: PDF XML Embed" at the lower right. You can click on the "PDF" link to get the PDF version of the guide.
Tincho85
Post by Tincho85 »
Hi Gene, you said that the black wire goes to the Rambo and the red one to the PSU unit.
Like this then? It might seem silly but I need to double check
and what about the 6 wires that goes from the PSU to the Rambo?
Should we still connect the first 2? If I remember correctly those are the ones that feed the bed.
Martín S.
geneb wrote:Right below the "Files" section, there's a bit that says "Formats: PDF XML Embed" at the lower right. You can click on the "PDF" link to get the PDF version of the guide.
Thank you Gene, you are the man!
cloneit3d
Post by cloneit3d »
I got my machine today and the package looked a little beat up with lots of melamine bits floating around although I assume they are not needed. There could have been more done on the inside to protect the contents. Hope everything is ok. I took pictures as part of documenting the build from start to finish.
Self designed plasma cutting table running Mach3
Orbot Hadron running and E3d 6, Smoothie on an Azteeg Mini, LCD, fully adjustable glass bed of my design with a silicone mat heater.
Prtrbot Simple Metal
Table top CNC running Mach 3
Tincho85 wrote:Hi Gene, you said that the black wire goes to the Rambo and the red one to the PSU unit.
The wiring goes like this:
1 12ga Black Wire - X tower
1 12ga Black Wire - Y Tower
2 26ga White Wires - Y Tower (thermistor wires from Onyx)
1 12ga Red Wire - Z Tower
The 12ga black wire from the onyx goes into the power connector for the heated bed.
The other 12ga black & red wires go into the power connection for the rambo - there'll be detail on that later - I apologize for the delay!
There should be jumper wires included to jumper the other two positions on that connector, just like the v2 was wired with the dedicated power supply.
The power wiring to and from the rambo are not performed until you reach the final assembly task. If you're there and you need help with the wiring, please email support.
Tincho85
Post by Tincho85 »
geneb wrote:The wiring goes like this:
Sorry, I'm not building a V3, still have the old model. But I'm experiencing a very annoying sound from the PSU when the bed is regulating the temperature.
So I wanted to try to connect it like this instead, maybe I get lucky and the sound disappears.
Martín S.
Apparently I take really bad notes.
Here's the correct wiring:
X tower = 1x 12ga black + 2x 26ga white. Used for heated bed to rambo
Y tower = 1x 12ga red. Used for psu to rambo power input
Z tower = 1x 12ga black. Used for psu to rambo power input
*facedesk*
Thanks Gene, you are 100% correct and John from SeeMeCNC verified how to download the docs as a PDF and it all works fine!!!
Maddog
Post by Maddog »
What temperature does that thermal fuse "pop"? The web site and manual says nothing I could find.
That new hot end is a major good move. I hate RTV and it takes forever to assemble. The new hot end looks like a drone with 3 motors.
Anybody independent reviewed the autoleveling feature yet? Does it work good? How accurate is it?
While putting all the goodies up top may work for SEEMECNC, being top heavier is not a good thing. It's taller right? It was tall enough already.
I personally would have added a cable routing channel down along the back side of the Z tower like other vendors and left the controller down south.
The cabling would be simple, modifiable and easier to trouble shoot. Try to add an extruder as is.
I prefer all the motors down by the power supply and not having the controller/display up high.
Good news going to 24 volts and dropping the PC power supply. That was a kludge from day one.
Making all the stepper mounts the same and with injected parts was a nice touch.
I would like to see stepper vibration mounts that reduce noise. Cork gaskets work?
They fixed it so you can tighten the belts without 3 hands? Phillips Screwdriver, wrench and flat screwdriver. I prefer to use 2 hands.
I was hoping they would add a dual extruder option and a real place for the filament spool to go.
travelphotog
Post by travelphotog »
On Monday a nice big white box with a cool logo on it is set to arrive at the 713maker shop. Steve and the crew at SeemeCNC have been very kind and sent 713maker.com out a printer from one of the few first batches of V3 kits so we can start working on some ideas for the V3 we have. We also ordered in another accel board for testing on the V2 we already have in the shop and to help us rapidly design and test an adapter to fit the accel board to our current mounts and effector system. We will also look at an adaptor to work with under mounted hot ends and the accel board as we know a fair number of folks like under mounted hot ends. We also ordered in some of the new cooling fans and will be working to see if they might be adopted to our effector plates while still keeping the maximum amount of inner space so everyone can run their hot end of choice on the V2 and V3 printers. We are setting up the studio this weekend so we can document the build and post a nice build log on the V3 so everyone can get a good feel for the build compared to the V2. We are extremely grateful to Steve and the gang at SeemeCNC for sending us the V3 for product development and know we have a big challenge ahead of us on the V3 since it really seems like the guys did an amazing job of adding some great new features. When our printer arrives Monday we will start our build post and try to document the steps as best we can along the way.
Return to “RostockMAX v3”
