M579
Posted: Fri Aug 23, 2019 1:39 pm
Hello, first off I don't usually post, I am able to find what I need by searching the forum, but not this time.
Calibrating max v2 with duet3dwifi, I make adjustments for my x,y, axis, get them where I want them using the M579 command, save using M500.
They stay till I power down. I did put the M501 at the end of config.g.
Am I using the right commands,or is there a proper sequence of operation.
Machine takes and uses what I put in (M579), changes are made to test piece, just lose it after power off.
Rostock Max V2
Duet3d wifi
fsr's
3dv6 hotend
Thank You
Carl
Rostock Max V2
Duet3d wifi
fsr's
3dv6 hotend
Thank You
Carl
