Should we tighten nozzle at temperature
Posted: Mon Aug 11, 2014 3:39 pm
The original nozzle became clogged on my Rostock Max 2. Replacing it was very straight forward:
Order new nozzle (http://forum.seemecnc.com/viewtopic.php?f=59&t=6069)
Drop two arms into transport position.
Heat hot end to 240.
Use 3/8 in wrench to remove nozzle.
Cool hot end.
Install new nozzle.
The hot nozzle was not tight at all. It would have turned with fingers (if they were fireproof). Now for the question: Should we be tightening the nozzle once it is at temperature or just leave it alone and check for looseness when cool?
Cool hot end.
Install new nozzle.
