Printhead digging into the print.
Posted: Thu Jan 05, 2017 8:49 pm
by knightwolf313
Ok, So I upgraded the hot end on my V2 to a e3dv6 chimera hot-end and I also updated the firmware. I started getting problems on my prints that are 2.5+hrs after a while, the motor clicks a little and the hot-end starts digging down into the print in one direction(toward the X tower) I re-installed the old firmware and it is still doing the same thing. it seams to print anything under 2.5 hrs just fine. I checked the motor current in the firmware and it is correct at {155,155,155,165,0}
Re: Printhead digging into the print.
Posted: Thu Jan 05, 2017 9:06 pm
Can you correlate the issue to the height of the print rather than time? Any multi nozzle hot end requires absolutely planar movement parallel to the bed. How did I you level the nozzles?
Posted: Fri Jan 06, 2017 3:22 am
by DeltaCon
Which firmware do you have? I had the same current problem after migrating to repetier 0.92.x. It seems the #define_motorcurrent statement changed to percentages instead of a 1-255 value. So you could be overdriving the stepperdrivers. if the problem occurs, lay your fingertop on the small stepper chips on the rambo. If you can't keep touching them because they are too hot, this is probably your problem. If it is, look here: http://forum.seemecnc.com/viewtopic.php ... age#p91113
Posted: Sat Jan 07, 2017 10:37 pm
by knightwolf313
Thanks DeltaCon, I was using actual figures not percentages, as soon as I switched over it no longer dug into the print.
Posted: Sun Jan 08, 2017 8:08 am
by DeltaCon
Glad I could help. Already saw your post on Facebook ;-)
