Rambo End Stop Connector
The RAMBo board is finally here, and here's a place to talk about it!
Pyropainter
Postby Pyropainter » Tue Dec 29, 2015 4:34 am
My intention is to get my Rostock Max v2 set up so I can utilize the Open DACT software on my machine. I realize that I will need to add a micro switch to the existing electronics of my machine. The trouble that I am having is locating a supplier that sells the connectors that plug into the Rambo board. I am sure that I am Googling the wrong questions. Will you help me locate someone that sells the connector that allows micro switches to be connected to the Rambo Controller. Please add the correct name for these connection so that I may know what to call them the future.
Thank you in advance.
magicmushroom666
Re: Rambo End Stop Connector
Postby magicmushroom666 » Tue Dec 29, 2015 5:56 am
Dupont connectors are a good start. You can always use those with standard pitch headers.
Pyropainter
Postby Pyropainter » Wed Dec 30, 2015 3:32 am
Thank you for your help. I got to thinking that these connectors look similar to the ones used in the RC Model Airplane World (something I pretended to do in another life). I dug thru some of my old stuff and found some old servo connectors and extensions. I believe I will try this for now. What I would like to find is a connector that has the retaining mechanism. Anyone have a source for them?
Thank you.
Postby Eaglezsoar » Wed Dec 30, 2015 5:25 am
Pyropainter wrote:Thank you for your help. I got to thinking that these connectors look similar to the ones used in the RC Model Airplane World (something I pretended to do in another life). I dug thru some of my old stuff and found some old servo connectors and extensions. I believe I will try this for now. What I would like to find is a connector that has the retaining mechanism. Anyone have a source for them?
Thank you.
See here: http://www.hansenhobbies.com/products/c ... in_lp_1x4/
Pyropainter
Postby Pyropainter » Fri Jan 01, 2016 4:31 pm
Thanks for your help, I will check them out.
Return to “RAMBo”
Who is online
Users browsing this forum: No registered users and 0 guests
