Rambo and the Viki Display
The RAMBo board is finally here, and here's a place to talk about it!
Postby Eaglezsoar » Mon Nov 16, 2015 7:14 pm
Has anyone successfully interfaced the Pannucatt Viki display with the Rambo controller and if so could you briefly tell us what needs to
be done to make it work?
Eric
Re: Rambo and the Viki Display
Postby Eric » Mon Nov 16, 2015 7:59 pm
There's nothing about the hardware that's incompatible. It's all about firmware support, and there are many firmware choices.
In Repetier it appears to be supported. Set FEATURE_CONTROLLER to 5 in "configuration.h". Also make sure pin assignments in "ui.h" are correct for whatever rambo pins you choose to use.
Can't help much beyond glancing at the code, as I don't own either a Rambo or a Viki.
Return to “RAMBo”
Who is online
Users browsing this forum: No registered users and 0 guests
