V3.2 Duet access port model file?
This forum is for discussions specific to the Duet-equipped Rostock MAX v3.2 3D printer.
nurbie
Post by nurbie » Fri May 17, 2019 5:47 pm
Do these Duet cover panel and access 'port/window' models live anywhere on the github archives as .stl/other?
I was going to mod the V3 LCD panel / fit the Duet access port to that if so.
also,
My current Duet mount places SD access about 3.2cm from the side panel.
Are you V3.2/4 operators using a mount that moves the Duet closer to the edge?
Any .stl's for those?
If not I can just mod the .stl/other file to be more inset.
Return to “Rostock MAX v3.2”
