Spindle Frequency?
lukebarber
Spindle Frequency?
Post by lukebarber » Sun Jan 13, 2019 7:45 pm
I bought and installed a new 1.5kw water-cooled spindle with an inverter to run it. Inverter is https://www.valinonline.com/products/esv152n02yxb . Now whenever I switch the spindle on it triggers my limit switches (in Mach3) and I can only reset it when the spindle is not running. Would adding a line reactor to the inverter help? Spindle and limit switch wiring is all shielded and properly grounded.
I'm virtually at a standstill. Any help?
ULTIMATE 3D JEDDI
Re: Spindle Frequency?
Post by geneb » Mon Jan 14, 2019 8:30 am
I would reconfigure your limit switches as normally closed. That will prevent electrical interference from generating false triggers.
